SN55ALS195,SN75ALS195,pdf(Quad
消耗积分:2 | 格式:rar | 大小:440 | 2010-09-04
彭友旺
分享资料个
The SN55ALS195 and SN75ALS195 are four differential line receivers with 3-state outputs designed using advanced low-power Schottky technology. This technology provides combined improvements in die design, tooling production, and wafer fabrication, which in turn, provide lower power consumption and permit much higher data throughput than other designs. The devices meet the specifications of ANSI Standards EIA/TIA-422-B and EIA/TIA-423-A and ITU Recommendations V.10 and V.11. The 3-state outputs permit direct connection to a bus-organized system with a fail-safe design that ensures the outputs will always be high if the inputs are open.
The devices are optimized for balanced multipoint bus transmission at rates up to 20 megabits per second.
评论(0)
发评论
下载排行榜
