The TUSB6015 is a USB 2.0 HS Peripheral Controller designed for seamless interface to an external Host processor through the NOR FLASH-like interface.
The NOR FLASH-like interface is a 16-bit, multiplexed address/data, interface with support for synchronous burst and single asynchronous read/write access. Configuration registers are accessible via the asynchronous chip select only; the End Point FIFO's are accessible via both the synchronous and asynchronous chip selects.
The device also has eight user configurable general purpose I/0 interface pins. The GPIO can be configured as an interrupt or wakeup source. Some GPIO have secondary NOR-flash DMA Request functionality.
The device is fully compliant with the Universal Serial Bus Specification Rev. 2.0.
The ESD protection level is 2KV HBM (JESD22- A114D), 500V CDM (JESD22-C101C).
