LM4558 pdf datasheet (DUAL OPE
消耗积分:10 | 格式:rar | 大小:443 | 2008-12-11
分享资料个
The LM4558 devices is a monolithic integrated circuit designed for dual operational amplifier.
The high common-mode input voltage range and the absence of latch-up make these amplifiers ideal for
voltage-follower applications. The devices are short-circuit protected and the internal frequency compen
-sation ensures stability without external components.
The LM4558 is characterized for operation from 0oC TO 70oC.
评论(0)
发评论
下载排行榜
