EL2360 pdf datasheet (Triple 1
消耗积分:3 | 格式:rar | 大小:555 | 2009-01-17
无人岛
分享资料个
The EL2360 is a triple currentfeedback
operational amplifier which
achieves a -3dB bandwidth of 130MHz
at a gain of +2. Built using the Elantec proprietary monolithic
complementary bipolar process, these amplifiers use current
mode feedback to achieve more bandwidth at a given gain
than a conventional voltage feedback amplifier.
The EL2360 is designed to drive a double terminated 75Ω
coax cable to video levels. It’s fast slew rate of 1500V/μs,
combined with the triple amplifier topology, makes its ideal
for RGB video applications.
This amplifier can operate on any supply voltage from 4V
(±2V) to 33V (±16.5V), yet consume only 8mA per amplifier
at any supply voltage. The EL2360 is available in 16-pin
PDIP and SOIC packages.
For Single, Dual, or Quad applications, consider the EL2160,
EL2260, or EL2460 all in industry standard pin outs. For
Single applications with a power down feature, consider the
EL2166.
评论(0)
发评论
下载排行榜
