ISL97642 pdf datasheet (TFT-LC
消耗积分:2 | 格式:rar | 大小:333 | 2009-03-05
分享资料个
The ISL97642 integrates a high performance boost regulator
with 2 LDO controllers for VON and VOFF, a VON-slice circuit
with adjustable delay and three amplifiers for VCOM and
VGAMMA applications.
The boost converter in the ISL97642 is a current mode PWM
type integrating an 18V N-Channel MOSFET.
Using external low-cost transistors, the LDO controllers
provide tight regulation for VON, VOFF, as well as providing
start-up sequence control and fault protection.
The amplifiers are ideal for VCOM and VGAMMA
applications, with 150mA peak output current drive, 12MHz
bandwidth, and 12V/μs slew rate. All inputs and outputs are
rail-to-rail.
评论(0)
发评论
下载排行榜
