PCM1753/PCM1754/PCM1755 pdf da
消耗积分:5 | 格式:rar | 大小:444 | 2009-03-06
学电超人
分享资料个
The PCM1753/54/55 is a CMOS, monolithic, integrated circuit, which includes stereo digital-to-analog converters and support circuitry in a small 16-lead SSOP package. The data converters use TI’s enhanced multilevel delta-sigma architecture, which employs 4th-order noise shaping and 8-level amplitude quantization to achieve excellent dynamic performance and improved tolerance to clock jitter. The PCM1753/54/55 accepts industry-standard audio data formats with 16- to 24-bit data, providing easy interfacing to audio DSP and decoder chips. Sampling rates up to 200 kHz are supported. A full set of user-programmable functions is accessible through a three-wire serial control port, which supports register write functions.
The PCM1753/55 is pin compatible with the PCM1748, PCM1742, and PCM1741, except for pin 5.
评论(0)
发评论
下载排行榜
