The MAX16952 is a current-mode, synchronous PWMstep-down controller designed to operate with input voltagesfrom 3.5V to 36V while using only 50μA of quiescentcurrent at no load. The switching frequency isadjustable from 1MHz to 2.2MHz by an external resistorand can be synchronized to an external clock up to2.4MHz. The MAX16952 output voltage is pin programmableto be either 5V fixed, or adjustable from 1V to 13V.The wide input voltage range, along with its ability tooperate in dropout during undervoltage transients,makes it ideal for automotive and industrial applications.
