The MAX16963 is a high-efficiency, dual synchronousstep-down converter that operates with a 2.7V to 5.5Vinput voltage range and provides a 0.8V to 3.6V outputvoltage range. The device delivers up to 1.5A of loadcurrent per output. The low input/output voltage rangeand the ability to provide high output currents make thisdevice ideal for on-board point-of-load and postregulationapplications. The device achieves Q3% output error overload, line, and temperature ranges.
