Abstract: This application note details a step-by-step design process for the MAX16833 high-voltagehigh-brightness LED driver. This process can speed up prototyping and increase the chance for firstpass
success. A typical design scenario is presented, along with example calculations based on thedesign constraints. Component selection trade-offs are discussed. A spreadsheet calculator is included tohelp calculate external component values. This application note focuses on the boost converter topology.However, the same process can be applied to other topologies as long as the underlying equations are
understood.
