4094 CMOS 8级移位存储总线寄存器
消耗积分:5 | 格式:rar | 大小:68 | 2009-08-08
分享资料个
The CD4094BC consists of an 8-bit shift register and a 3-
STATE 8-bit latch. Data is shifted serially through the shift
register on the positive transition of the clock. The output of
the last stage (QS) can be used to cascade several
devices. Data on the QS output is transferred to a second
output, Q¢S, on the following negative clock edge.
The output of each stage of the shift register feeds a latch,
which latches data on the negative edge of the STROBE
input. When STROBE is HIGH, data propagates through
the latch to 3-STATE output gates. These gates are
enabled when OUTPUT ENABLE is taken HIGH.
评论(0)
发评论
下载排行榜
