2N3705 pdf datasheet
消耗积分:2 | 格式:rar | 大小:333 | 2008-07-08
远不及你
分享资料个
Small Signal Transistors
TO-92 Case
72
www.centralsemi.com
TYPE NO. DESCRIPTION LEAD VCBO VCEO VEBO ICBO @ VCB hFE @ VCE @ IC VCE (SAT) @ IC Cob fT NF toff
CODE (nA)
(V) (V) (V) *ICES (V) *hFE (V) (mA) (V) (mA) (pF) (MHz) (dB)
*VCES *ICEV (1kHZ) *Crb *TYP
MIN MIN MAX MAX MIN MAX MAX MIN MAX MAX
2N2712 NPN AMPL/SWITCH ECB 18 18 5.0 500 18 75 250 - - - - - - - - 12 2.8 - -
2N2714 NPN AMPL/SWITCH ECB 18 18 5.0 100 18 75 250 0.30 50 1.20 50 - - - - - - - -
2N2923 NPN LOW NOISE ECB 25 25 5.0 100 25 90 180* - - - - - - - - 10 160* - - - -
2N2924 NPN LOW NOISE ECB 25 25 5.0 100 25 150 300* - - - - - - - - 10 160* - - - -
2N2925 NPN LOW NOISE ECB 25 25 5.0 100 25 235 470* - - - - - - - - 10 160* 2.8 - -
2N2926 NPN LOW NOISE ECB 25 25 5.0 500 18 35 470* - - - - - - - - 10 120* 2.8 - -
2N3391A NPN LOW NOISE ECB 25 25 5.0 100 25 250 500 4.50 2.0 - - - - 10 120* 5.0 - -
2N3392 NPN LOW NOISE ECB 25 25 5.0 100 25 150 300 4.50 2.0 - - - - 10 120* - - - -
2N3393 NPN LOW NOISE ECB 25 25 5.0 100 25 90 180 4.50 2.0 - - - - 10 120* - - - -
2N3395 NPN LOW NOISE ECB 25 25 5.0 100 25 150 500 4.50 2.0 - - - - 10 - - - - - -
2N3396 NPN LOW NOISE ECB 25 25 5.0 100 25 90 500 4.50 2.0 - - - - 10 - - - - - -
2N3397 NPN LOW NOISE ECB 25 25 5.0 100 25 55 500 4.50 2.0 - - - - 10 - - - - - -
2N3398 NPN LOW NOISE ECB 25 25 5.0 100 25 55 800 4.50 2.0 - - - - 10 - - - - - -
2N3415 NPN LOW NOISE ECB 25 25 5.0 100 25 180 540 4.50 2.0 0.30 50 - - - - - - - -
2N3416 NPN LOW NOISE ECB 50 50 5.0 100 25 75 225 4.50 2.0 0.30 50 - - - - - - - -
2N3417 NPN LOW NOISE ECB 50 50 5.0 100 50 180 540 4.50 2.0 0.30 50 - - - - - - - -
2N3702 PNPAMPL/SWITCH ECB 40 25 5.0 100 20 60 300 5.0 0.05 0.25 50 12 100 - - - -
2N3703 PNPAMPL/SWITCH ECB 50 30 5.0 100 20 30 150 5.0 0.05 0.25 50 12 100 - - - -
2N3704 NPN AMPL/SWITCH ECB 50 30 5.0 100 20 100 300 2.0 50 0.60 100 12 100 - - - -
2N3705 NPN AMPL/SWITCH ECB 50 30 5.0 100 20 50 150 2.0 50 0.80 100 12 100 - - - -
2N3706 NPN AMPL/SWITCH ECB 40 20 5.0 100 20 30 600 2.0 50 1.0 100 12 100 - - - -
2N3707 NPN LOW NOISE ECB 30 30 6.0 100 20 100 400 5.0 1.0 1.0 10 - - - - 5.0 - -
2N3708 NPN LOW NOISE ECB 30 30 6.0 100 20 45 660 5.0 1.0 1.0 10 - - - - 5.0 - -
2N3709 NPN LOW NOISE ECB 30 30 6.0 100 20 45 165 5.0 1.0 1.0 10 - - - - 5.0 - -
2N3710 NPN LOW NOISE ECB 30 30 6.0 100 20 90 330 5.0 1.0 1.0 10 - - - - 5.0 - -
2N3711 NPN LOW NOISE ECB 30 30 6.0 100 20 180 660 5.0 1.0 1.0 10 - - - - 5.0 - -
2N3859A NPN LOW NOISE ECB 60 60 6.0 50 60 100 200 4.50 2.0 0.125 10 4.0 - - 5.0 - -
2N3860 NPN LOW NOISE ECB 30 30 4.0 50 30 150 300 4.50 2.0 0.125 10 4.0 90 - - - -
2N3903 NPN AMPL/SWITCH EBC 60 40 6.0 50* 30 50 150 1.0 10 0.30 50 4.0 250 6.0 225
2N3904 NPN AMPL/SWITCH EBC 60 40 6.0 50* 30 100 300 1.0 10 0.30 50 4.0 300 5.0 250
2N3905 PNPAMPL/SWITCH EBC 40 40 5.0 50* 30 50 150 1.0 10 0.40 50 4.5 200 5.0 260
2N3906 PN AMPL/SWITCH EBC 40 40 5.0 50* 30 100 300 1.0 10 0.40 50 4.5 250 4.0 300
2N4058 PNP LOW NOISE ECB 30 30 6.0 100 20 100 400 5.0 0.10 0.70 10 - - - - 5.0 - -
2N4123 NPN AMPL/SWITCH EBC 40 30 5.0 50 20 50 150 1.0 2.0 0.30 50 4.0 250 6.0 - -
2N4124 NPN AMPL/ SWITCH EBC 30 25 5.0 50 20 120 360 1.0 2.0 0.30 50 4.0 300 5.0 - -
2N4125 PNP AMPL/SWITCH EBC 30 30 4.0 50 20 50 150 1.0 2.0 0.40 50 4.5 200 5.0 - -
2N4126 PNPAMPL/SWITCH EBC 25 25 4.0 50 20 120 360 1.0 2.0 0.40 50 4.5 250 4.0 - -
2N4264 NPN SAT SWITCH EBC 30 15 6.0 12 40 160 1.0 10 0.35 100 4.0 350 - - 35
2N4287 NPN LOW NOISE ECB 45 45 7.0 10 30 150 600 5.0 1.0 0.35 1.0 6.0 40 5.0 - -
2N4289 PNP LOW NOISE ECB 60 45 7.0 10 45 150 600 0.35 1.0 0.80 1.0 8.0 40 4.0 - -
2N4400 NPN AMPL/SWITCH EBC 60 40 6.0 100* 35 50 150 1.0 150 0.75 500 6.5 200 - - 255
评论(0)
发评论
下载排行榜
