SCAN92LV090,pdf datasheet (9 C
消耗积分:2 | 格式:rar | 大小:550 | 2009-10-13
分享资料个
The SCAN92LV090A is one in a series of Bus LVDS
transceivers designed specifically for the high speed, low
power proprietary backplane or cable interfaces. The device
operates from a single 3.3V power supply and includes nine
differential line drivers and nine receivers. To minimize bus
loading, the driver outputs and receiver inputs are internally
connected. The separate I/O of the logic side allows for loop
back support. The device also features a flow through pin out
which allows easy PCB routing for short stubs between its
pins and the connector.
评论(0)
发评论
下载排行榜
