LMH0202,pdf datasheet (Dual SM
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-14
申换换
分享资料个
The LMH0202 Dual SMPTE 292M / 259M serial digital cable
driver is a monolithic, high-speed cable driver designed for
use in SMPTE 292M / 259M serial digital video and ITU-T
G.703 serial digital data transmission applications. The
LMH0202 drives 75Ω transmission lines (Belden 8281,
Belden 1694A or equivalent) at data rates up to 1.485 Gbps.
The LMH0202 provides two selectable slew rates for
SMPTE 259M and SMPTE 292M compliance. The output
voltage swing is adjustable via a single external resistor.
评论(0)
发评论
下载排行榜
