ADM1186,datasheet,pdf(Quad Vol
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-22
mintsy
分享资料个
The ADM1186-1 and ADM1186-2 are integrated, four-channel
voltage monitoring and sequencing devices. A 2.7 V to 5.5 V
power supply is required on the VCC pin for power. Four precision comparators, VIN1 to VIN4, monitor four
voltage rails. All four comparators share a 0.6 V reference and have a worst-case accuracy of 0.8%. Resistor networks that are external to the VIN1, VIN2, VIN3, and VIN4 pins set the
undervoltage (UV) trip points for the monitored supply rails.
The ADM1186-1 and ADM1186-2 have four open-drain enable outputs, OUT1 to OUT4, that are used to enable power supplies. An open-drain power-good output, PWRGD, indicates whether the four VINx inputs are above their UV thresholds.
评论(0)
发评论
下载排行榜
