ADP3051,datasheet,pdf(500 mA P
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-23
王银喜
分享资料个
The ADP3051 is a low noise, current mode, pulse width modu-lator (PWM) step-down converter capable of supplying over 500 mA to output voltages as low as 0.8 V. This device integrates a low resistance power switch and synchronous rectifier, provid-ing excellent efficiency over the entire output voltage range and eliminating the need for a large and costly external Schottky rectifier. Its 550 kHz switching frequency permits the use of small external components.
评论(0)
发评论
下载排行榜
