3-V TO 5.5-V MULTICHANNEL RS-2
消耗积分:3 | 格式:rar | 大小:226 | 2009-11-03
分享资料个
The MAX3243E device consists of three line drivers, five line receivers, and a dual charge-pump circuit with±15-kV ESD (HBM and IEC61000-4-2, Air-Gap Discharge) and ±8-kV ESD (IEC61000-4-2, Contact Discharge)protection on serial-port connection pins. The device meets the requirements of TIA/EIA-232-F and provides theelectrical interface between an asynchronous communication controller and the serial-port connector. Thiscombination of drivers and receivers matches that needed for the typical serial port used in an IBM PC/AT, orcompatible. The charge pump and four small external capacitors allow operation from a single 3-V to 5.5-Vsupply. In addition, the device includes an always-active noninverting output (ROUT2B), which allowsapplications using the ring indicator to transmit data while the device is powered down. The device operates atdata signaling rates up to 250 kbit/s and a maximum of 30-V/ms driver output slew rate.
评论(0)
发评论
下载排行榜
