LTC3564 pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-08-04
分享资料个
The LTC3564 is a high efficiency monolithic synchronous buck regulator using a constant frequency, current mode architecture. Supply current during operation is only 20μA, dropping to ≤1μA in shutdown. The 2.5V to 5.5V input voltage range makes the LTC3564 ideally suited for single Li-Ion battery-powered or 3.3V to 5V input voltage applications. 100% duty cycle provides low drop- out operation, extending battery life in portable systems. Automatic Burst Mode operation increases efficiency at light loads, further extending battery runtime.
Switching frequency is internally set at 2.25MHz, allowing the use of small surface mount inductors and capacitors.
The internal synchronous switch increases efficiency and eliminates the need for an external Schottky diode. Low output voltages are easily supported with the 0.6V feedback reference voltage. The LTC3564 is available in low profile (1mm) ThinSOT and 6-Lead (2mm × 3mm) DFN packages.
评论(0)
发评论
下载排行榜
