TLC5928 pdf datasheet (16 Chan
消耗积分:3 | 格式:rar | 大小:555 | 2008-08-19
欲望都市
分享资料个
The TLC5928 is a 16-channel, constant current sink LED driver. Each channel can be turned on/off by writing serial data to an internal register. The constant current value of all 16 channels is set by a single external resistor.
The TLC5928 has two error detection circuits: one for LED open detection (LOD) and one for a pre-thermal warning (PTW). LOD detects a broken or disconnected LED and LEDs shorted to GND while the constant current output is on. PTW indicates a high temperature condition.
评论(0)
发评论
下载排行榜
