ONET2591TA,pdf(2.5 Gbps Transi
消耗积分:5 | 格式:rar | 大小:659 | 2010-08-28
5762
分享资料个
The ONET2591TA is a high-speed transimpedance amplifier used in optical receivers with data rates up to 2.5 Gbps.
It features a low input referred noise, 1.8-GHz bandwidth, automatic gain control (AGC), 2.6-k transimpedance, and received signal strength indication (RSSI).
The ONET2591TA is available in die form and is optimized for use in a TO can.
The ONET2591TA requires a single 3.3-V supply, and its power-efficient design typically dissipates less than 53 mW. The device is characterized for operation from -40°C to 85°C ambient temperature.
评论(0)
发评论
下载排行榜
