SN75157,pdf(Dual Differential
消耗积分:2 | 格式:rar | 大小:476 | 2010-09-03
王伟
分享资料个
The SN75157 is a dual differential line receiver designed to meet Standards EIA/TIA-422-B and -423-B and ITU V.10 and V.11. It utilizes Schottky circuitry and has TTL-compatible outputs. The inputs are compatible with either a single-ended or a differential-line system. The device operates from a single 5-V power supply and is supplied in 8-pin dual-in-line and small-outline packages.
The SN75157 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
