LMV710,LMV711,LMV715,pdf(SINGL
消耗积分:3 | 格式:rar | 大小:626 | 2010-09-17
李静
分享资料个
The LMV710, LMV711, and LMV715 are single BiCMOS operational amplifiers designed to meet the demands of low power, low cost, and small size required by battery-powered portable electronics. These devices have an input common-mode voltage range that exceeds the rails, rail-to-rail output, and high output-current drive. The devices offer a bandwidth of 5 MHz and a slew rate of 5 V/µs.
On the LMV711 and LMV715, a separate shutdown pin can be used to disable the device and reduce the supply current to 0.2 µA typical. The device features a turn-on time of less than 10 µs. It is an ideal solution for power-sensitive applications, such as cellular phones, pagers, palm computers, etc.
The LMV710I, LMV711I, and LMV715I are characterized for operation from –40°C to 85°C.
评论(0)
发评论
下载排行榜
