The THS7318 is a very low power single-supply 3 channel device designed to process Y’, P’B, P’R enhanced definition TV and Y’, C’, and CVBS standard definition TV signals. It integrates circuitry to perform signal processing commonly required in video output applications.
All channels incorporate 3rd-order 20-MHz Butterworth DAC reconstruction filters designed for video systems with 54 MSPS DAC sampling rates like NTSC/PAL 480p/576p EDTV and 480i/576i SDTV video.
Rail-to-Rail output drivers on all channels allow for both ac and dc coupled outputs.
The low quiescent current makes it an excellent choice for USB powered or portable video applications.
The THS7318 is available in a 9-pin NanoFree™ wafer scale package.
