TPS60300,TPS60301,TPS60302,TPS
消耗积分:3 | 格式:rar | 大小:538 | 2010-10-06
分享资料个
The TPS6030x step-up, regulated charge pumps generate a 3-V ±4% or 3.3-V ±4% output voltage from a 0.9-V to 1.8-V input voltage (one alkaline, NiCd, or NiMH battery).
Only five small 1-uF ceramic capacitors are required to build a complete high efficiency dc/dc charge pump converter. To achieve the high efficiency over a wide input voltage range, the charge pump automatically selects between a 3x or 4x conversion mode.
评论(0)
发评论
下载排行榜
