TPS2590,pdf(3-V to 20-V High C
消耗积分:3 | 格式:rar | 大小:1173 | 2010-10-28
贾永世
分享资料个
The TPS2590 provides highly integrated hot-swap power management and superior protection in applications where the load is powered by voltages between 3.0 V and 20 V. This device is intended for systems where a voltage bus must be protected to prevent load shorts from interrupting or damaging other system components. The TPS2590 is in a 16-pin QFN package.
The TPS2590 has multiple programmable protection features. Load protection is accomplished by a non-current limiting fault threshold, a hard current limit threshhold, and a fault timer. The dual current thresholds allow the system to draw high current for short periods without causing a voltage droop at the load. An example of this is a disk drive startup.
评论(0)
发评论
下载排行榜
