TLC5916-Q1,TLC5917-Q1,pdf(8-Bi
消耗积分:3 | 格式:rar | 大小:629 | 2010-11-03
张涛
分享资料个
特性
  • Qualified for Automotive Applications
  • Eight Constant-Current Output Channels
  • Output Current Adjusted Through External Resistor
  • Constant Output Current Range: 5 mA to 120 mA
  • Constant Output Current Invariant to Load Voltage Change
  • Open Load, Short Load, and Overtemperature Detection
  • 256-Step Programmable Global Current Gain
  • Excellent Output Current Accuracy:
    • Between Channels: < ±3% (Max)
    • Between ICs: < ±6% (Max)
  • Fast Response of Output Current
  • 30-MHz Clock Frequency
  • Schmitt-Trigger Input
  • 3.3-V or 5-V Supply Voltage
  • Thermal Shutdown for Overtemperature Protection
  • APPLICATIONS
    • General LED Lighting Applications
    • LED Display Systems
    • LED Signage
    • Automotive LED Lighting
评论(0)
发评论
下载排行榜
