BQ24745,pdf(SMBus-Controlled M
消耗积分:10 | 格式:rar | 大小:1520 | 2010-11-09
分享资料个
The bq24745 is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5×5 mm2 QFN package.
The bq24745 features Dynamic Power Management (DPM) and input power limiting. These features reduce battery-charge current when the input power limit is reached to avoid overloading the AC adaptor when supplying the load and the battery charger simultaneously.
评论(1)
发评论
ouyangqz 2015-07-11
0 回复 举报
学习 收起回复
下载排行榜
全部1条评论
