PCM1600/PCM1601 pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The PCM1600(1) and PCM1601(1) are CMOS monolithic
integrated circuits which feature six 24-bit audio
digital-to-analog converters and support circuitry in
either a LQFP-48 or MQFP-48 package. The digitalto-
analog converters utilize Burr-Brown’s enhanced
multi-level, delta-sigma architecture, which employ
4th-order noise shaping and 8-level amplitude quantization
to achieve excellent signal-to-noise performance
and a high tolerance to clock jitter.
The PCM1600 and PCM1601 accept industry-standard
audio data formats with 16- to 24-bit audio data.
Sampling rates up to 100kHz are supported. A full set
of user-programmable functions are accessible through
a 4-wire serial control port which supports register
write and readback functions.
评论(0)
发评论
下载排行榜
