ISL97702 pdf datasheet (Boost
消耗积分:3 | 格式:rar | 大小:319 | 2009-01-15
123
分享资料个
The ISL97702 represents a high efficiency, boost converter
with integrated boost FET, boost diode and input disconnect
FET. A dual feedback circuit allows simple switching
between two pre-defined output voltages using a single logic
input.
With an input voltage of 2.3V to 5.5V the ISL97702 has an
output capability of up to 50mA at 18V using integrated
500mA switches. Efficiencies are up to 87%. The
integrated protection FET is used to disconnect the boost
inductor from the input supply whenever an output fault
condition is detected, or when the device is disabled. This
gives 0 output current in the disabled mode, compared to
standard boost converters where current can still flow when
The ISL97702 comes in the 10 Ld 3x3 DFN package and is
specified for operation over the -40°C to 85°C temperature
range.
评论(0)
发评论
下载排行榜
