The EL5027 is a dual, low power, high voltage rail-to-rail input-output buffer. Operating on supplies ranging from 5V to 15V, while consuming only 110μA per channel, the EL5027 has a bandwidth of 2.5MHz -(-3dB). The EL5027 also provides rail-to-rail input and output ability, giving the maximum dynamic range at any supply voltage. The EL5027 also features fast slewing and settling times, as well as a high output drive capability of 30mA (sink and source). These features make the EL5027 ideal for use as voltage reference buffers in Thin Film Transistor Liquid Crystal Displays (TFT-LCD). Other applications include battery power, portable devices, and anywhere low power consumption is important. The EL5027 is available in space-saving 6 Ld TSOT package and operates over a temperature range of -40°C to +85°C.
