【美信】MAX8814 线性Li+电池充电器
消耗积分:0 | 格式:pdf | 大小:215KB | 2014-08-21
孔令双
分享资料个
锂电池充电器
      The MAX8814 intelligent, stand-alone constant-current,constant-voltage (CCCV), thermally regulated linear charger is designed for charging a single-cell lithiumion (Li+) battery。 The MAX8814 integrates the currentsense circuit, MOSFET pass element, thermalregulation circuitry, and eliminates the reverse-blocking Schottky diode to create the simplest and smallest charging solution for handheld equipment。
评论(0)
发评论
下载排行榜
