74VCXH245英文手册
消耗积分:1 | 格式:zip | 大小:116KB | 2016-10-08
yejunjie176
分享资料个
The 74VCXH245 contains eight non-inverting bidirectional buffers with 3-STATE outputs and is intended for bus oriented applications. The T/R input determines the direction of data flow. The OE input disables both the A and B Ports by placing them in a high impedance state. The VCXH245 data inputs include active bushold circuitry, eliminating the need for external pull-up resistors to hold unused or floating data inputs at a valid logic level。
评论(0)
发评论
下载排行榜
