LMV112pdf datasheet (40 MHz D
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-08
分享资料个
The LMV112 is a high speed dual clock buffer designed for
portable communications and accurate multi-clock systems.
The LMV112 integrates two 40 MHz low noise buffers which
optimizes application and out performs large discrete solutions.
This device enables superb system operation between
the base band and the oscillator signal path while eliminating
crosstalk.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
