ADC12C080,pdf datasheet (12-Bi
消耗积分:2 | 格式:rar | 大小:551 | 2009-10-10
479809
分享资料个
The ADC12C080 is a high-performance CMOS analog-todigital
converter capable of converting analog input signals
into 12-bit digital words at rates up to 80 Mega Samples Per
Second (MSPS). This converter uses a differential, pipelined
architecture with digital error correction and an on-chip sample-
and-hold circuit to minimize power consumption and the
external component count, while providing excellent dynamic
performance. A unique sample-and-hold stage yields a fullpower
bandwidth of 1 GHz. The ADC12C080 may be operated
from a single +3.0V power supply and consumes low
power. A separate +2.5V supply may be used for the digital
output interface which allows lower power operation with reduced
noise. A power-down feature reduces the power consumption
to very low levels while still allowing fast wake-up
time to full operation. The differential inputs accept a 2V full
scale differential input swing. A stable 1.2V internal voltage
reference is provided, or the ADC12C080 can be operated
with an external 1.2V reference. Output data format (offset
binary versus 2's complement) and duty cycle stabilizer are
pin-selectable. The duty cycle stabilizer maintains performance
over a wide range of clock duty cycles.
评论(0)
发评论
下载排行榜
