DS92LV1224,pdf datasheet (30-6
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-14
分享资料个
The DS92LV1224 is a 300 to 660 Mb/s deserializer for
high-speed unidirectional serial data transmission over FR-4
printed circuit board backplanes and balanced copper
cables. It receives the Bus LVDS serial data stream from a
compatible 10–bit serializer, transforms it back into a 10-bit
wide parallel data bus and recovers parallel clock. This
single serial data stream simplifies PCB design and reduces
PCB cost by narrowing data paths that in turn reduce PCB
size and number of layers. The single serial data stream also
reduces cable size, the number of connectors, and eliminates
clock-to-data and data-to-data skew.
评论(0)
发评论
下载排行榜
