ADM660/ADM8660,datasheet,pdf(C
消耗积分:5 | 格式:rar | 大小:554 | 2009-10-23
丁冬芹
分享资料个
The ADM660/ADM8660 is a charge-pump voltage converter
that can be used to either invert the input supply voltage giving
VOUT = –VIN or double it (ADM660 only) giving VOUT = 2  VIN.
Input voltages ranging from +1.5 V to +7 V can be inverted into
a negative –1.5 V to –7 V output supply. This inverting scheme
is ideal for generating a negative rail in single power supply
systems. Only two small external capacitors are needed for the
charge pump. Output currents up to 50 mA with greater than
90% efficiency are achievable, while 100 mA achieves greater
than 80% efficiency.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
