TPL0501EVM用户指南
消耗积分:0 | 格式:PDF | 大小:380KB | 2017-05-17
汽车玩家
分享资料个
  特征
  •作品基于MSP430 Launchpad平台成本低
  •简单的GUI控制EVM
  •EVM可操作两种不同的模式,可调电压参考模式,可变增益模式
  •板完全由USB供电
  Introduction
  The TPL0501 is a single channel, linear-taper digital potentiometer with 256 wiper positions. This device can be used as a three-terminal potentiometer or as a two-terminal rheostat. The TPL0501 has an end –to-end resistance of 100kΩ。 The internal registers of the TPL0501 can be accessed using a SPI-compatible interface. The TPL0501 has a nominal temperature coefficient of 35ppm/°C. The TPL0501 is available in an 8-pin SOT-23 and 8-microQFN package with a specified temperature range of –40°C to 125°C
TPL0501EVM用户指南
评论(0)
发评论
下载排行榜
