CM0902双高速CAN收发器
消耗积分:0 | 格式:rar | 大小:0.55 MB | 2017-09-18
分享资料个
  The CM0902 is a SMARTMOS dual high-speed (up to 1.0 Mbit/s) CAN transceiver device, providing the physical interface between the CAN protocol controller of an MCU and the physical dual wire CAN bus. Both channels are completely independent, featuring CAN bus wake-up on each CAN interface, and TXD dominant timeout functionality (33CM0902 only)。 The CM0902 is packaged in a 14-pin SOIC, with industry standard pin out, and offers excellent EMC and ESD performance without the need for external filter components.The CM0902 comes in two variants: 33CM0902 and 34CM0902 for Automotive and Industrial applications respectively.
CM0902双高速CAN收发器
评论(0)
发评论
下载排行榜
