LED技术资料 KPPA-3010CGCK kingbright
消耗积分:0 | 格式:pdf | 大小:727KB | 2017-09-28
h1654155970.8622
分享资料个
KPPA-3010CGCK 绿光 波长568nm 发光二极管
  The Green source color devices are made with AlGaInP on GaAs substrate Light Emitting Diode.
  3.0x2.5x1.0mm right angle SMD LED, 1.0mm thickness. z Low power consumption. z Ideal for back light and indicator. z Package : 2000pcs / reel. z Moisture sensitivity level : level 3. z Tinned pads for improved solderability. z RoHS compliant.
评论(0)
发评论
下载排行榜
