aos(美国万代)5A IPM AIM5C05B060N1数据手册
消耗积分:3 | 格式:pdf | 大小:0.89 MB | 2017-12-25
A du
分享资料个
AOS(美国万代)推出的 5A IPM智能功率管理模块资料:
  Features and Functions
  • 600V-5A (Trench Shielded Planar Gate IGBT)
  • 3 phase Inverter module including HVIC drivers
  • Built-in bootstrap diodes with integrated current limiting resistor
  • Control supply under-voltage lockout protection (UVLO)
  • Over-temperature (OT) protection (VOT) – pin open
  • Temperature monitoring (VOT) – 5.1kΩ resistor connection
  • Short-circuit current protection (CSC)
  • Fault out signal (VFO) corresponding to SC, UV and OT fault
  • Wide input interface (3-18V), Schmitt trigger receiver circuit (Active High)
  • Isolation ratings of 2000Vrms/min
  Applications
  • AC 100~253Vrms class low power motor drives like refrigerators, dishwashers, fan motors, washing machines and air-conditioners Internal Equivalent Circuit
评论(0)
发评论
下载排行榜
