SN54BCT2240, SN74BCT2240,pdf(O
消耗积分:3 | 格式:rar | 大小:397 | 2010-07-12
张勇
分享资料个
These octal buffers and line drivers are designed specifically to improve both the performance and density of 3-state memory address drivers, clock drivers, and bus-oriented receivers and transmitters. Together with the SN74BCT2241 and the ’BCT2244 devices, these devices provide the choice of selected combinations of inverting and noninverting outputs, symmetrical active-low output-enable (OE)\ inputs, and complementary OE and (OE)\ inputs. These devices feature high fan-out and improved fan-in.
The ’BCT2240 devices are organized as two 4-bit line drivers with separate output-enable (OE)\ inputs. When (OE)\ is low, the device passes data from the A inputs to the Y outputs. When (OE)\ is high, the outputs are in the high-impedance state.
评论(0)
发评论
下载排行榜
