AD548 pdf,AD548 datasheet
消耗积分:5 | 格式:rar | 大小:555 | 2008-09-06
YYXIAO
分享资料个
The AD548 is a low power, precision monolithic operational
amplifier. It offers both low bias current (10 pA max, warmed
up) and low quiescent current (200 μA max) and is fabricated
with ion-implanted FET and laser wafer trimming technologies.
Input bias current is guaranteed over the AD548’s entire
common-mode voltage range.
The economical J grade has a maximum guaranteed input offset
voltage of less than 2 mV and an input offset voltage drift of less
than 20 μV/°C. This level of dc precision is achieved utilizing
Analog’s laser wafer drift trimming process. The combination of
low quiescent current and low offset voltage drift minimizes
changes in input offset voltage due to self-heating effects.
The AD548 is recommended for any dual supply op amp application
requiring low power and excellent dc and ac performance.
In applications such as battery-powered, precision instrument
front ends and CMOS DAC buffers, the AD548’s excellent combination
of low input offset voltage and drift, low bias current,
and low 1/f noise reduces output errors. High common-mode
rejection (82 dB, min on the “B” grade) and high open-loop
gain ensures better than 12-bit linearity in high impedance,
buffer applications.
The AD548 is pinned out in a standard op amp configuration
and is available in three performance grades. The AD548J and
AD548K are rated over the commercial temperature range of
0°C to 70°C. The AD548B is rated over the industrial temperature
range of –40°C to +85°C.
The AD548 is available in an 8-lead plastic mini-DIP and
surface-mount (SOIC) packages.
评论(0)
发评论
下载排行榜
