SN74ALVCH32501,pdf(36-BIT UNIV
消耗积分:2 | 格式:rar | 大小:414 | 2010-08-21
分享资料个
This 36-bit universal bus transceiver is designed for 1.65-V to 3.6-V VCC operation.
This device can be used as two 18-bit transceivers or one 36-bit transceiver. Data flow in each direction is controlled by output-enable (OEAB and OEBA\), latch-enable (LEAB and LEBA), and clock (CLKAB and CLKBA) inputs. For A-to-B data flow, the device operates in the transparent mode when LEAB is high. When LEAB is low, the A data is latched if CLKAB is held at a high or low logic level. If LEAB is low, the A data is stored in the latch/flip-flop on the low-to-high transition of CLKAB. When OEAB is high, the outputs are active. When OEAB is low, the outputs are in the high-impedance state.
Data flow for B to A is similar to that of A to B, but uses OEBA\, LEBA, and CLKBA.
评论(0)
发评论
下载排行榜
