The SN65HVDA1040A meets or exceeds the specifications of the ISO 11898 standard for use in applications employing a Controller Area Network (CAN). The device is qualified for use in automotive applications. As a CAN transceiver, this device provides differential transmit capability to the bus and differential receive capability to a CAN controller at signaling rates up to 1 megabit per second (Mbps)The signaling rate of a line is the number of voltage transitions that are made per second, expressed in the units bps (bits per second)(1).
The device is designed for operation in especially harsh environments and includes many device protection features such as undervoltage lock out, over temperature thermal shutdown, wide common-mode range and loss of ground protection.
