SN65HVDA1050A-Q1,pdf(EMC-Optim
消耗积分:5 | 格式:rar | 大小:481 | 2010-08-23
分享资料个
The SN65HVDA1050A meets or exceeds the specifications of the ISO 11898 standard for use in applications employing a Controller Area Network (CAN). The device is qualified for use in automotive applications. As a CAN transceiver, this device provides differential transmit capability to the bus and differential receive capability to a CAN controller at signaling rates up to1 megabit per second (Mbps)The signaling rate of a line is the number of voltage transitions that are made per second expressed in the units bps (bits per second)(1).
The device is designed for operation in especially harsh environments and includes many device protection features such as undervoltage lockout, over-temperature thermal shutdown, wide common-mode range, and loss of ground protection.
评论(0)
发评论
下载排行榜
