SN75374,pdf(QUADRUPLE MOSFET D
消耗积分:3 | 格式:rar | 大小:592 | 2010-08-30
分享资料个
The SN75374 is a quadruple NAND interface circuit designed to drive power MOSFETs from TTL inputs. It provides the high current and voltage necessary to drive large capacitive loads at high speeds.
The outputs can be switched very close to the VCC2 supply rail when VCC3 is about 3 V higher than VCC2. VCC3 can also be tied directly to VCC2 when the source voltage requirements are lower.
评论(0)
发评论
下载排行榜
