TPS61045,pdf(Digitally Adjusta
消耗积分:3 | 格式:rar | 大小:819 | 2010-10-01
张强
分享资料个
The TPS61045 is a high frequency boost converter with digitally programmable output voltage and true shutdown. During shutdown, the output is disconnected from the input by opening the internal input switch. This allows a controlled power up/down sequencing of the display. The output voltage can be increased or decreased in digital steps by applying a logic signal to the CTRL pin. The output voltage range, as well as the output voltage step size, can be programmed with the feedback divider network. With a high switching frequency of up to 1 MHz, the TPS61045 allows the use of small external components and together, with the small 8-pin QFN package, a minimum system solution size is achieved.
评论(0)
发评论
下载排行榜
