TPS54425,pdf(4-A Output Single
消耗积分:3 | 格式:rar | 大小:636 | 2010-10-03
分享资料个
The TPS54425 is an adaptive on-time D-CAP2 mode synchronous buck converter. The TPS54425 enables system designers to complete the suite of various end equipment’s power bus regulators with a cost effective, low component count, low standby current solution. The main control loop for the TPS54425 uses the D-CAP2 mode control which provides a very fast transient response with no external compensation components. The TPS54425 also has a proprietary circuit that enables the device to adopt to both low equivalent series resistance (ESR) output capacitors, such as POSCAP or SP-CAP, and ultra-low ESR ceramic capacitors. The device operates from 4.5-V to 18-V VIN input. The output voltage can be programmed between 0.
评论(0)
发评论
下载排行榜
