TPS53129,pdf(Dual Synchronous
消耗积分:3 | 格式:rar | 大小:771 | 2010-10-05
胡秋阳
分享资料个
The TPS53129 is a dual, adaptive on-time D-CAP2™ mode synchronous buck controller. The TPS53129
enables system designers to complete the suite of various end equipment’s power bus regulators with cost
effective, low component count, and low standby current solution. The main control loop for the TPS53129 uses
the D-CAP2™ mode control which provides a very fast transient response with no external components. The
TPS53129 also has a circuit that enables the device to adapt to both low equivalent series resistance (ESR)
output capacitors such as POSCAP or SP-CAP, and ultra-low ESR, ceramic capacitors. The fixed frequency
emulated adaptive on-time control supports seamless operation between PWM mode at heavy load condition
and reduced frequency operation at light load for high efficiency down to milliampere range.The device provides
convenient and efficient operation with input voltages from 4.5 V to 24 V and output voltages from 0.76 V to
5.5 V.
The TPS53129 is available in 4-mm x 4-mm 24-pin QFN (RGE) or 24-pin TSSOP (PW) packages, and is
specified from -40°C to 85°C ambient temperature range.
评论(0)
发评论
下载排行榜
