TPS53126,pdf(Dual Synchronous
消耗积分:2 | 格式:rar | 大小:858 | 2010-10-05
小峰
分享资料个
The TPS53126 is a dual, adaptive on-time, D-CAP2 mode synchronous Buck controller. The TPS53126 enables system designers to complete the suite of various end equipment's power bus regulators with a cost effective, low external component count, and low standby current solution. The main control loop for the TPS53126 uses the D-CAP2 mode control which provides a very fast transient response with no external components. The TPS53126 also has a proprietary circuit that enables the device to adapt to both low equivalent series resistance (ESR) output capacitors, such as POSCAP or SP-CAP, and ultra-low ESR ceramic capacitors. The device provides convenient and efficient operation with input voltages from 4.5 V to 24 V and output voltages from 0.
评论(0)
发评论
下载排行榜
