PTH05T210W,pdf(30-A 4.5-V-5.5-
消耗积分:2 | 格式:rar | 大小:1135 | 2010-11-16
分享资料个
The PTH05T210W is a high-performance 30-A rated, non-isolated power module which utilizes a multi-phase, switch-mode topology. This module represents the 2nd generation of the PTH series power modules which includes a reduced footprint and improved features.
Operating from an input voltage range of 4.5 V to 5.5 V, the PTH05T210W requires a single resistor to set the output voltage to any value over the range, 0.7 V to 3.6 V. The module uses double-sided surface mount construction to provide a low profile and compact footprint. Package options include both through-hole and surface mount configurations that are lead (Pb) – free and RoHS compatible.
A new feature included in this 2nd generation of PTH modules is TurboTrans™ technology (patent pending).
评论(0)
发评论
下载排行榜
